Dirty oil between 1,500k oil change?
My 99 z28 with 78k and good maintance records. I changed my oil and filter with castrol syntec 5w30 and 2 months and 1500 miles later my change oil light came on so I changed the oil. Sure enough the oil was very black. This can not be a good sign with such little time and milage between changes. Why is the oil so dirty? Does the engine need attention?
Oil gets discolored, fast, I am not surprised it looked dirty at 1500 miles.
How do I re set the oil light? I changed my oil but the light is still on. It should not be running rich, I just have the Slp air intake kit and an exhaust, not mods to the cats and stock manafolds.
Turn the key foward to "on" but do not start. Press the gas pedal down three times in a row quickly and you should see the light go off.
strange, im about to change my oil (its been 3000 since the change), its just a tan brown. I did seafoam it a year ago, i think that was definately a step in the right direction, the motor seems to run alot stronger now than it did before.
but if its not black by 3000 miles on a 112k motor, i guess that means im in good shape?
Originally Posted by lostsurferguy
Whats sea faom a engine degreaser or something that goes in the oil?
