New LS1 Owners - Newbie Tech - LS6 Intake Install ????'s
View Full Version : LS6 Intake Install ????'s
Ricks99ls1
08-26-2007, 04:38 PM
Ok i have been taking my time sanding, and prepping, finally painted my intake navy blue metallic and it looks phenominal, anyways i was going to attempt to install tonight and was wondering if you all would mine dropping me some pointers for installing, any little details to make this easier would be appreciated, i have the directions from ls1 howto but we all know once you get in and do it there are a million other things, thanks for any help you may lend
IROC403
08-26-2007, 04:49 PM
its pretty simple, theres a vac. line thats hard to reach in the back.
ooh yeah, dont break the plastic oil pressure switch!!!!!!!
Ricks99ls1
08-26-2007, 04:57 PM
ive heard about that switch where is it located?
99Hawk262
08-26-2007, 05:04 PM
I tried so hard not to break the oil pressure sending unit.....and broke it anyway. :( :jest: Not a bad idea to have a new one on hand in case. The brake booster hose goes to the back of the intake....the oil sender unit is below/in front of that and from what I understand what usually snags and breaks the sender. I'd try to pull that hose out of the brake booster and then rotate it up and out of the way if possible. Take your time and you should be okay. It's a snap once you get it out. Good luck and enjoy the new power!!
Ricks99ls1
08-26-2007, 09:30 PM
is the oil pressure sensor like a cylinder shaped sensor? it screws into the block at the rear of the intake if so i broke the damned thing...does anyone have a part number also, once you get the intake out i use the front new coolant line i bought and plug the back two correct?
BlackDuk98
08-26-2007, 09:47 PM
Yep, you broke it. Here is a pic and a part number for an ac delco one. I ordered an extra when I did mine, but I disconnected the line at the booster, and it moved easily enough that it didn't break, so now I have this laying around.
http://i131.photobucket.com/albums/p288/BlackDuk98/MVC-490S.jpg?t=1188182830
Ricks99ls1
08-26-2007, 10:34 PM
also if my ls6 intake has the ridges ground off, do i need to change any of the coolant lines, and do i need to use the plugs for the rear coolant lines, or do i keep all the lines under the intake?
BlackDuk98
08-26-2007, 10:41 PM
If the ridges are ground off, you can keep what you have on the car now. Some people change it over and don't want to do the grinding, some choose to save $$ and grind the ridges away. I chose the latter.
Ricks99ls1
08-26-2007, 10:46 PM
how much was the oil pressure sending sensor? i just wanna thank you man, i was really pissed when all this happened, now im feeling kinda confident when i hit it again tomorrow, when you did it was it a noticeable mod? and if so where did you notice the power down low or high in the powerband
BlackDuk98
08-26-2007, 10:51 PM
It could be diff in your area, but since i work at a shop, i get the net price discount.
net= $28.63
list= $40.90
I felt it higher in the powerband, but I wasn't that impressed w/ the difference. Not that noticeable to me. Headers seemed better. Every bit helps though
remember, put the last 4 intake bolts on the back of the intake in before you put the intake under the cowl, otherwise, you won't get them in after......
Glad I could help. If you need any more help, let me know. I gotta go get some sleep or i will be dead at work tomorrow..
LSWon00
08-26-2007, 11:00 PM
All said and done should take you about an hour with changing the sending unit.
Ricks99ls1
08-26-2007, 11:03 PM
awesome guys i am going to hit it hard after work tomorrow and see how it goes, i was hoping the gain would be noticeable, but alot of people are saying otherwise
night ghost
08-27-2007, 10:01 AM
just make sure that u use ur stock bolts cause the ones u will get with the manifold are never as good and quite a bit weaker
i make that mistake and broke one in half but if u do break one and it is inthe hole just go to a a home depot or a lows and get something called like a reverse screw i think
