Opinions: Lunati vs. Comp Cam
Looking for some input on the differences between the same grind comp cam vs. a lunati. Given a choice, which cam would you put in your car, and why?
I know lunati had some grind and ramp rate issues about a year to two years ago, is this still seen as a problem?
Input appreciated.
Input appreciated.
Re: Opinions: Lunati vs. Comp Cam
I've had two lunati cams in the past two years, and no problems. I think that they have a slower ramp rate than the comp extreme energy ones. Both companies are using the same core now. Lunati used to use a billet piece for their LS1 cams. You can't lose either way. They both make a good product.
