Gears & Axles - 98 corvette gears
nassaublue
08-27-2007, 10:03 AM
if i take out my stock 3:23 and put 3:73 gears in will my rearend go out shortly after? will i need to tune my car for these gears or is the stock tune fine? wher is the best place to buy gears?
gyrene2003
08-27-2007, 10:22 AM
As long as the gears are done and setup by someone with lots of experience with our cars and setup properly than ur rear end will be just fine. the stock tune will be fine, the only thing that needs to be adjusted will be the speedo, but thats a simple fix and only takes 5 minutes if u have access to a programer or have friends that have them for ur year. mine hums alittle but that because the shims arent "perfectly placed" But i was thier and did the install with 2 very expereinced f-body guys, so i know it was done right. Mine are motive, which are a popular brand because of thier price and quality. Richmonds are strong but will make noise but they say thats normal for how they cut thier gears. ive already been to the track on sticky tires and beaten on mine! Most of the sponsors sell various brands.
gyrene2003
08-27-2007, 10:23 AM
Oh and if ur an auto, i would say go 3.90, thats what i did and couldnt be happier or imagine going through that trouble for a smaller gear.
keliente
08-27-2007, 11:02 AM
The rear should be ok with 3.73's. With a vette you are more likely to break the output shaft before you'd break the gears anyway. If you do not retune for the new gears your speedometer will be off.
chicane
08-27-2007, 04:38 PM
It would probably be in your best interest to merely do an exchange... vice an R&P swap. That... and it would save you a whole bunch of headache, not to mention money.
The 8.25" gears run about an average of $385.00 and are available through a few different manufacturers. Now you'll need to find someone qualified to do the build and then add on the R&R and set-up costs.
Look up RPM Transmissions (http://www.rpmtransmissions.com/). They can help aleviate most of your soon-to-be headache.
nassaublue
08-27-2007, 05:42 PM
lol damn man i cant do anything cheap to my car damn corvettes i should have bought a trans am or something i just put a new motor and tranny in it so yeah 385 is alot right now. thanks though man
Camaro396
08-27-2007, 06:54 PM
from what i heard from a couple buddies who did a 3.23 to 3.73 swap, there was not a noticable difference.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
