squealing at full lock
Old 08-27-2007, 11:27 AM
devin.flohr@us.army.'s Avatar
Default squealing at full lock
When turning at low speed with the wheel at full lock there is a low squealing or howling sound coming from the front of the car. The car is all stock so idk any ideas?
Old 08-27-2007, 02:47 PM
shaun's Avatar
both my cars do that and also some other ones i have owned. my 04 escalade did that when i got it and i added some of the lucas stearing stuff and it went away and also the same deal with me z. just buy some lucas and it will go away.
Old 08-27-2007, 03:33 PM
derekderek's Avatar
It's normal any car you drive when you turn the wheel full left/right the power steering pump is going to whine alittle bit. I would'nt worrie to much about it.
Derek
Old 08-29-2007, 03:21 AM
waldershrek's Avatar
Is it more of a whine or a squeal?
whine = normal
squeal = not normal
check the fluid just to be safe and add some Lucas PS additive
Old 08-29-2007, 05:36 AM
Roadhouse's Avatar
It's not good practice to hold at full lock, puts alot of strain on the pump and lines.
Old 08-29-2007, 06:31 AM
That's true also especially if you fluid is low
Old 08-29-2007, 07:39 PM
sdm1234's Avatar
check tire pressures as well. one of them may be only sqeueeling during sharp cornering.
Old 08-29-2007, 08:03 PM
FU_I_AM_UltraZ's Avatar
miles on it? have you checked the wheel bearings?
