number 7 piston is clean car had ticking
Old 08-27-2007, 04:04 PM
mrclean200518's Avatar
Default number 7 piston is clean car had ticking
i just recently had a ticking in my car and i pulled the head off the driver side and the number 7 piston is clean and and both valves are dirty and the spark plug is oiley but the first 3 cylinders are dirty with carbon and 1 of each valve is dirty and the other is a tanish color.
Old 08-28-2007, 04:24 AM
navymitch12's Avatar
sounds like you blew the head gasket and got some coolant into the #7 cyl...take some pics of the cyl, head gasket, and head to know more
Old 08-28-2007, 10:32 AM
thanks for the info man , the headgasket rings and stuff look good i took it and let a machine shopcheck it out i sucked something up and it bounced aroudn in there pitted the top of the head and got into the valve seat and roughed it up a bit
