LS1 Edit and Autotap woes
OK as you may have known from previous posts I have been running my car with the rear 02s only. Even when I autotapped it the first time. Now I have the fronts running and I autotapped it. My log has to be wrong. LTERMS are all always 0 and I know thats wrong.
Maybe I am logging the wrong thing. Can someone please help me by:
1> listing the things I need the values e.g. 02 sensor b1s1 ect. I need to log to check for Rich lean situations and to check to see if my injectors are holding up like they should? I get a spudder sometimes when in high rpms. Could you give a ball park of where each value should read at wot and idle.
2> I also have some more egr codes to delete but I dont know what to turn off in edit. I turned off everything that had egr or air and I still get the air and egr codes.
3> what do I turn off to delete the rear o2 sensors?
I know I am lost in this programming stuff but this should get me started. If someone could reply.
Thanks in advance,
Thanks in advance,
