Help:car stalling vacuum leak? what does this mean
Old 05-27-2003, 07:00 PM
smokinHawk's Avatar
Default Help:car stalling vacuum leak? what does this mean
background: single turbo kit, 224/224-114 cam. M6 transmission. 42lb svo injectors.
Ok my car stalls all the time, when you let off the gas, been doing this for awhile.
Today i have been messing with it to see if theres a vacuum leak.
I have stumble on to something: When you disconect the vacuum line from the intake it doesnt stall, it act normal.
ofcours now it is sucking air through the intake vacuum conector.
when i hook the vacuum port/line up to the fuel vacuum (thing?) without connectiong the wasteggate, bov boost gauge it stalls like it did with everything connected
Old 05-27-2003, 07:47 PM
smokinHawk's Avatar
Default Re: Help:car stalling vacuum leak? what does this mean
FIgured it out FINALLY!
turned out when i redid my pvc system i pluged the passenger side valve, but this needs air.
unplugged it and it runs fine now.
Quick Reply: Help:car stalling vacuum leak? what does this mean
