LS6 Intake Install... HELP!
Have the old one off, now I need to relocate the coolant lines, I purchased the new coolant line and 2 plugs... but have no clue what I am supposed to move to where. If anyone can help or provide before and after pics it was be greatly appreciated
Thanks
-Andrew
Thanks
-Andrew
Re: LS6 Intake Install... HELP!
Thanks for the reply, So it looks like the entire line that runs from the front of the engine to the rear gets deleted?
Two coolant plugs go on the rear and the new little coolant pipes just replaces the one on the front?
Pay attention to the little oval shaped washers that have the o-ring in them. Sometimes they get stuck to the heads and sometimes they come off with the coolant pipe. Make sure that there is one installed on on each end of the new coolant pipe and one on each plug with none stuck on the heads. And be sure you remove the two green plastic clips from the knock sensor wiring harness. Peel the tape back and remove them completely. They can keep the manifold from setting flush on the heads.
