Generation IV External Engine - L76/L92 Guys..
the_merv
08-28-2007, 07:28 PM
If you can, post up what numbers you have gotten out of your setups, and what you have built.
I am Dynoing here soon..I'm wondering what you guys have so I can compare it to mine for a rough idea..:drive:
WKMCD
09-07-2007, 06:00 AM
It's all in here. 500RWHP/Mild build
http://ls1tech.com/forums/showthread.php?t=662314
505/475 at the wheels.
402ci LS2 11:1 compression
STG 3 Livernois L92s
stock L76 intake
240/252 .650/.661 114+3 cam
1 3/4 jet hot headers
stock LS1 MAF
should make more once i go with bigger headers, go speed density, put an underdrive pulley on, and hopefully ill have another option for intake manifold
89Formulaws6
09-08-2007, 11:15 AM
i'm new to tuneing but how to just going over to speed density help you pick up more power, cause when i take mine to get tunded, and converting isn't hard i'd prolly do the same
because the maf is only 78mm in diameter, and is a decent restriction when your flowing that much air. just take off the maf and put a coupler straight from your lid to your throttle body. should pick up a decent amount for a bigger cubed motor IMO. tuner will just tune in speed density mode.
if your maf isnt pluged in or doesnt work, your car goes into speed density mode
WKMCD
09-08-2007, 12:13 PM
Speed Density won't net you more peak RWHP than a properly tuned closed loop engine. It can improve drivability with larger cams.
89Formulaws6
09-08-2007, 12:18 PM
cool thats the idea i was thinking it helped. i have truck/vette maf its alot bigger then the stock one so i dont think its a restriction at all anymore
thanks for the help
why not when your going from a 78mm opening with some restriction, to a free flowing 90mm opening.
thats like saying a stock throttle body will make just as much power as a 90mm
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
