Which Cam makes the most power from around 2k-6k?
Old 08-29-2007, 07:20 AM
95N20FORMULA's Avatar
Default Which Cam makes the most power from around 2k-6k?
Not trying to spin the motor super high, so what cam(dont say hotcam) is the best if i dont really want to spin pst 6k 6200 at the most? Im think cc305 or cc503?
Old 08-29-2007, 07:27 AM
JoeliusZ28's Avatar
cc503
Old 08-29-2007, 07:34 AM
this cam is supposed to pull and make peak power at 1500-5800, so 6k would be a good shift point?
Old 08-29-2007, 07:40 AM
JoeliusZ28's Avatar
id say so. some will rev that cam higher to get the most out of it, but i dont think its necessary per se.
Old 08-29-2007, 09:06 AM
street demon2k3's Avatar
look into the crane227, it makes a ton of power under the curve and should keep you a little over the stock shift points. might be a better all around cam since it doesnt need lots of RPM's to make power, and you can keep your stock tuning.
Old 08-29-2007, 09:19 AM
i dont need to keep stock tuning, but where do i find this cam and how much is it?
Old 08-29-2007, 09:24 AM
slick1851's Avatar
Not a fan of off the shelf ****.......GET A CUSTOM ONE
Call up one of our sponsers and talk to them and tell them what you want, its a lil more but worth it
T/A KID's Avatar
My CC503 cam is for sale if anyone is interested?
Old 08-29-2007, 12:22 PM
This cam makes a lot of tq under the curve, and most will say it works really well on stock heads. I was going to buy it but I decided to go custom instead, if it would have been in stock when i had the $$$ I would have bought it. here's a link....
http://store.summitracing.com/egnsea...=KeywordSearch
Old 08-29-2007, 03:28 PM
Bersaglieri's Avatar
I'd go with the biggest of the mid size guys. GM846. 222/230
-Dustin-
Old 08-29-2007, 11:18 PM
phirepower's Avatar
+1
Old 08-29-2007, 11:19 PM
phirepower's Avatar
except I think you mean Gm grind 847
Old 08-30-2007, 07:06 AM
No I mean GM846 222/230. Its what I would run in this case. The GM847 234/242 is way to big to be under-rev'ed to 6200rpm.
Where in Mass you from? Go to NED often?
-Dustin-
Old 09-01-2007, 06:44 PM
phirepower's Avatar
oh when i installed my hotcam way back it had 846 on the cam and on the cam sheet... weird
Quick Reply: Which Cam makes the most power from around 2k-6k?
