Th400 Temp Sending Unit?'s
Where are you guys taping for the temperature gauge sending unit? Besides the tans pan... I found a threaded hole on the drivers side of the trans case, Has anyone used that before?
Is that what you are doing?
I have a trans cooler that totally enclosed in a case, the case gets filled with ice+water before the run, i don't think trans temps will be a problem for me.
My PG case has 4 ports on the case 2 labeled out, 1 in, and one with nothing but i have an aftermarket case.
My pan also has a port.... maybe performabuilt will chime in when they see this to help out some more.
