2003 LS6 Heads any good?
Old 08-29-2007, 10:08 PM
Restricted User
socmguy's Avatar
Default 2003 LS6 Heads any good?
I have a friend with a set of these for sale. I have a 2000 Z28 w/ bolt-ons and a Torquer v.2 232/234 .595 .598 112lsa. What would the gains be? Is it worth the money?
Old 08-29-2007, 10:29 PM
Tainted's Avatar
a set of ls6 heads are worth about 20hp over stock ls1 heads, ported they fetch even more. get'em!
Old 08-30-2007, 08:57 AM
Restricted User
socmguy's Avatar
I'm seriously thinking about it. bump
Old 08-30-2007, 10:07 AM
got milk??'s Avatar
hey if they are fully assembled and cheap get um, all u need to do is get them shaved down alittle to bump the compression i wouldnt bother getting them ported for the money its gonna cost(compared to buying aftermarket castings ported) just get them shaved with that cam u will be making good power throughout the band dont focus on the peak as it will only be around 410-415ish assuming u have other supporting mods but your down low and midrange will be killer! i had a set of those on my 98 with the exact same cam peak numbers werent great but like i said down low that car got up and went! i hope this helps you btw im in the havelock new bern area.
Old 08-30-2007, 10:57 AM
Restricted User
socmguy's Avatar
they've got PRC duals on them and he wants $500ish. I'm not in to peak #s, more interested in under the curve power.
How much should I deck them?
what size head gasket should I use?
Will my stock rockers work with these?
and what are the casting/serial #s I should be looking for?
Old 08-30-2007, 01:29 PM
bowe1632's Avatar
casting number is 243...your stock rockers should work...and I picked up some Felpro head gaskets from Jegs along with some ARP bolts, spent a bit on them but definetly worth the money. For 500, they are worth your money. Cartridge rolling heads like that can go a long way.
Old 08-30-2007, 06:08 PM
Restricted User
socmguy's Avatar
Do you remember if the Felpro head gaskets were stock size or custom. I'm seriously considering this right now.
Old 08-30-2007, 06:09 PM
Evans752's Avatar
stock size Im pretty sure
Old 08-30-2007, 06:12 PM
Tainted's Avatar
stock rockers work
milling is up to you
felpro's you just need the stock size
500ish is a good deal
Ported is even better
Old 08-30-2007, 06:47 PM
Restricted User
socmguy's Avatar
hey tainted, how much should I mill them, what would the CR be bumped to, and do you know of any good shops in town that would be able to do the work?
Old 08-30-2007, 11:10 PM
02TransAm/Batmobile's Avatar
If you swap those heads onto your LS1, it'll increase the compression ratio to 10.5:1 compared to 10.1:1. Milling them .030" will increase your compression ratio to 11.1:1.
That is great for under the curve power and down low torque!
Old 08-30-2007, 11:29 PM
98RedZone's Avatar
I think the springs are worth $250-$275 alone.
Old 08-31-2007, 12:07 AM
Restricted User
socmguy's Avatar
Are there ANY downsides to 11.1:1 CR? I realize I'll have to use ONLY 93+ octane.
Will I have to fly cut w/ a Tv.2 Cam?
Any worries spraying N2O?
Old 08-31-2007, 11:42 AM
Restricted User
socmguy's Avatar
Is there any way to tell if the heads had been previously milled?
Old 08-31-2007, 03:11 PM
CodeName Z06's Avatar
I am thinking of milling my ls6 heads with the Torquer 3, does any one know how much you can mill with out having PTV issues?
Or maybe running a thinner gasket?
Old 08-31-2007, 03:35 PM
TheLS1Kid's Avatar
I'd definitely get the LS6 heads!
Theres nothing wrong with running an 11.1:1 CR.
I'm running 11.5:1 and I'm fine with 93 octane.
Old 08-31-2007, 05:03 PM
LS1Kid, did you mill your heads?
Old 08-31-2007, 05:44 PM
TheLS1Kid's Avatar
No, they came from Patriot with 59cc chambers.
Old 08-31-2007, 10:17 PM
3fingas's Avatar
Always check PTV. Maybe shorter P-rods. The mill doesnt have to be more than .030 normally.
Old 09-01-2007, 08:52 AM
2 SSlow's Avatar
i bought brank new 243 casting for $395, stock valves for $25, and patriot springs for like $250. If the springs are almost new, it wouldn't be a bad deal. If the springs have 15k-20k miles on them i would just buy new ones IMO...
