P0430 code?
Old 08-29-2007, 10:09 PM
BlackNiteWS6's Avatar
Default P0430 code?
I had this code come up on my car. Is this code usually a bad rear O2 sensor or is the cat. bad itself?
Old 08-30-2007, 06:23 AM
2001WS6Vert's Avatar
It's almost always the cat.. Should be covered by the 8yr./80k warranty.
Old 09-29-2007, 03:42 AM
Well, i still have a problem. As i post earlier i have a P0430 code. So i took it to the dealer yesterday and they replace both passenger side O2's and the cat. Drove 5 miles from the dealer and BAMM the SES light came back on. Drove back to dealer, they scanned it with Tech 2 and the 0430 code came back. What the heck else can cause this? I told the dealer i want the PCM either replaced, or erased then re-flash with a new stock file. Just wanted to know who's seen this?
Den
Old 09-29-2007, 03:51 AM
WS6Drop's Avatar
Its common with longtube headers and cats. All you need to do is get O2 sims or tuned out.
Old 10-04-2007, 07:39 PM
Cruz28's Avatar
If you have headers you will need the tune. I have headers, cats and all four oxygen sensors. Get the tune instead of the sims that way you fix the problem and drive back home with more power. I got rid of my PO420 & PO430 codes and gained 20hp and 19tq with a dyno tune.
Old 10-04-2007, 08:10 PM
2xLS1's Avatar
Your sig says FLP headers. How did a dealer replace a FLP cat? It also says LS1 Edit. Just turn the codes off with it. Or is this on a different car?
Old 10-04-2007, 08:44 PM
Cruz28's Avatar
I didn't look at his sig before I typed what I thought was a good way to go, strange he didn't take care of this already with LS1 edit.
Quick Reply: P0430 code?
