does not idle up when brake booster hose is disconnected
Old 08-30-2007, 06:02 PM
9formula4's Avatar
Default does not idle up when brake booster hose is disconnected
OK so I am seafoaming my motor today. I start the car and let it warm up. When warm i pulled off the brake booster line, BUT instead of idling up it about died. It idled up when the seafaom was added but when I would stop it would drop again. I got the seafaom in and reinstalled the hose and it went back to normal idle.
Why does mine not idle up like its suppose to?? I have a cam if that makes any diff.
Old 08-30-2007, 06:13 PM
ThoR294's Avatar
check your idle air control motor passage. you have acess to a scan tool?
Old 08-30-2007, 06:21 PM
9formula4's Avatar
no access to a scan tool right now.
Old 08-31-2007, 05:33 PM
SLawson86's Avatar
picture a huge vacuum leak... when you have a large vacuum leak, its not metered air, therefore no more fuel is being added to compensate. thats why your car doesnt idle up. the iac can compensate for a smaller vacuum leak, but your brake booster is the largest vacuum line on the car.
Old 08-31-2007, 06:13 PM
ThoR294's Avatar
my car compensated when i pulled the brake booster hose. it still ran...
Quick Reply: does not idle up when brake booster hose is disconnected
