How to make my exhaust LOUDER?
Right now i have a Borla exhaust it sounds pretty good but you know you could always go louder. Does anyone have any ideas on a cheap and easy way to make my exhaust a little louder? And also without cutting anything.
Whats the Pro XS one? Like i said the first owner installed the exhaust and the receipt says it was only $679.99. And that its just the Borla adjustable cat back system.
step 1: remove cat-back
step 2: listen to louder car
I think thats about the only way you could do it if you dont have plates... or you could try
step 1: install cut-out
step 2: open cut-out
step 3: listen to louder car
Originally Posted by lastcall190
Too expensive? Not a chance. For what you can sell the borla for, you should be able to snag the TSP duals.
TD's are nothing cost wise compared to a Borla.
You could get a hammer and a big screwdriver and hammer some holes into the muffler. That would cost $0 if you have the tools already.
I think though you should check to make sure it doesn't have the full block of plate in it. If it does you can remove it. If that is too loud I am sure you could fabricate a plate with a small hole to put in there.
