Where are some good points to pry off the oil pan?
Old 08-31-2007, 01:00 PM
00 Freak's Avatar
Default Where are some good points to pry off the oil pan?
Just like it says. I got to the part where I'm going to swap my oil pump and got the 10 small bolts off and having a lil trouble prying the oil pan to come down. Well the part i was prying so far was the front part of the oil pan, but I did some research quite a few people cracked that part and having leaks. I don't want to damage the oil pan or the block.
Old 08-31-2007, 02:09 PM
5.3LJimmy's Avatar
You also need to take the 2 long bolts out of the back of the pan and the 2 bottom transmission bolts. Don't pry on it!
Old 08-31-2007, 02:49 PM
00 Freak's Avatar
I'm going thru the direction on the ls1howto.com and didn't mention anything about un bolting tranny bolts.
Old 08-31-2007, 03:19 PM
5.3LJimmy's Avatar
I just looked at the ls1howto instructions and it does not say to take them out, but in the picture that shows the back 2 bolt loose you can see the bolt is removed. Trust me take them out or you will crack the pan.
Old 08-31-2007, 03:25 PM
00 Freak's Avatar
would the tranny fluid spill out? All of my oil pans are full of oil.
Old 08-31-2007, 03:31 PM
5.3LJimmy's Avatar
You are not taking the bolts out of the transmission pan. The ones I'm talking about are bolting the tranny to the engine. At the back of the pan 2 bolts go thru the transmission bellhousing and into the oil pan(on the engine). If you are having trouble understanding what I'm talking about you need to find someone to help you who does. A new oil pan is gonna cost you 250 bucks and it's not fun to change.
Old 08-31-2007, 03:40 PM
5.3LJimmy's Avatar
I sent you a PM w/ my cell #. Call if you need more help.
Old 08-31-2007, 04:15 PM
00 Freak's Avatar
Well 5.3Jimmy was correct!! No need to pry on the oil pan! This wasn't mentioned on ls1howto.com. The oil pan just drops when those 2 tranny bolts from the buttom bellhousing are removed. Was able to remove the oil pump in about 2 min. and now the next frustration. 5.3LJimmy you're my hero!!!!
Old 08-31-2007, 04:16 PM
00 Freak's Avatar
Someone needs to warn the correct person to fix the website!
Quick Reply: Where are some good points to pry off the oil pan?
