Question guys????????
Old 09-01-2007, 01:03 PM
CAMARO SS 2000's Avatar
Default Question guys????????
hi guys
I have camaro ss 2000
the car has bolt-ones
now I think about the cam and heads
I purchased the T-Rex cam and I think to Purchase AFR Head 255c
but there are two kind of heads 255c
my question which is the better ?
1-AFR 225cc LS1 Cylinder Heads with 72cc chamber assembled with 2.08" / 1.60" Valves, dual coil valve springs(.600" max lift), and Titanium retainers.
2-AFR 225cc LS1 Small Bore Cylinder Heads with 65cc chamber assembled with 2.08" / 1.60" Valves, dual coil valve springs(.600" max lift), and Titanium retainers.
see guys the difference between them. The number of chamber assmled .
I don't know which one I will buy and what's the difference between them and which better for the engine . I need your help guys
I'm waiting your reply
thanks
Old 09-01-2007, 08:10 PM
boola1341's Avatar
where did u purchase ur t rex cam from?
Old 09-01-2007, 09:17 PM
68chevypu's Avatar
the numbers are the combustion chamber size
bigger numbers will give you lower compression and less power. However lower compression can be helpful with power adders (turbo/nitrous)
