Carbeurated LT1
Carbing an LT1 is what ignorant people who refuse to LEARN do.
There are no advantages, injection is superior and actually quite easy to tune with the right tools which are suprizingly inexpensive.
Start adding up the cost of jets, timing light, advance springs etc. and compare that too $90 for Tunercat and $40+ for a cable and injection can be cheap to tune. The feedback the computer can offer makes tuning much easier too.
I was thinking about doing a carb lt1 setup but that was only to make forced induction easier to tune. I wouldn't really swap one unless it would only going to be driven a quarter mile at a time. If you spend the extra money on a wideband and read up on how to tune a good carburetor then you can really make them run great.
But for driveability you'll never rival fuel injection.
In-Zane Moderator
[QUOTE=ZONES89RS]
Start adding up the cost of jets, timing light, advance springs etc. and compare that too $90 for Tunercat and $40+ for a cable and injection can be cheap to tune. QUOTE]
I got all that **** laying around, so unless you dona already have this ****, he has a good point. A serious plus for me would be not having to worry about water in the opti, i am scared to drive my **** in heavy rain.
If anyone is wanting to an inferior system (ie Carbed) because of the opti, then you should buy a mustang or somthing. Delteq and LTCC fix that problem of the opti. Granted both systems still use the opti, but no voltage is running through the opti. Its only there for timing.
The only reason to do a carbed LT1 is a swap into an older vehicle. It would be cheaper and easier. Example LT1 in an 80's modile S-10. the truck is already set up for a carb so its easier to keep it carbed.
That is just because you are STUPID, you dumbass kids on the internet blow things way out of proportion.
Every year os so I make trips too the east coast and on several of those trips I have ended up perfectly pacing nasty storms, 15+ hours straight of driving through HEAVY rain, I mean so bad you have to follow semis because they squeege the road ahead of you. Gone through 3" of water at speed with 255/50/17 rubber pumping up walls of water so dense you can't see out the side windows and no opti problems.
That little packet of grease that comes with plug wires, use it on the wires and on the weatherpack connector too the opti and it seals perfectly. I have put over 170K miles on LT1s and never had a water problem with an opti that was any worse than a slight miss for a couple minutes and that is even rare, so if you have water problems with the opti is it operator error not the opti.
EVERY distributor will act up if water gets into it, the opti is placed where it can be more suceptible too water but is also much better sealed than other distributors. When I offroaded trucks I drowned out the HEI a few times, it is up high but no so sealed.
Some of the younger people on the forum are not dumbasses, but I do agree that the statement about the opti was pretty stupid, for one I have driven mine in the heavy rain and have had no problems. I do have a nice set of msd wires on it though.
In-Zane Moderator
You are a flaming *** bag ******, i am tired of you talking **** you dumb bitch, i am not a kid so **** off, i really wish you would stop running your head, i have had bad experience with the opti, in the rain i have had them **** up, you dont drive an F body so maybe you dont have the same experiences, so stop talking ****.
Take Care,
Daren
