Can you????
Can you????
Hey guys...
Can you change the pistons and rods without pulling the motor? Or would i wanna get some machine work done when changing the pistons??
Thanks
Thanks
yes you can as long as the engine is suppoerted....the k member will have to go and of course the heads....just check the cylinders with a bore gauge when you get it all apart......
Originally Posted by dyls1
No. Yes.
hell you could pull the tranny and do a crank install as well........
I would go the other route and start by yanking the engine, but that is just me.
