Tips for installing LS7 clutch?
Old 09-01-2007, 09:09 PM
noxiouSS's Avatar
Default Tips for installing LS7 clutch?
Will i need to shim it? does it come with an alighnment tool? what can i use to get the flywheel on and off?
Old 09-01-2007, 10:53 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You don't need to shim it and you will need an alignment tool. You can use a impact to get the flywheel off and a 1/2 drive ratchet to put it on
Old 09-02-2007, 12:27 AM
ae13291's Avatar
no need for shim and if i were u i would go with a lighter flywheel because the the ls7 clutch + pressure plate setup is about 15 pounds heavier, and also when reinstalling the tranny to the car, loosen the bleeder screw to releave the hydralic pressure in the slave so the transmission bolts tighten easy goodluck
Old 09-02-2007, 09:26 AM
noxiouSS's Avatar
where can i get an alighnment tool?
Old 09-02-2007, 11:35 AM
00silverz28's Avatar
I got one at autozone.
Old 09-02-2007, 02:20 PM
ski23's Avatar
i just installed ls7/ls2 setup yesterday. my kit did not come with a damn alignment tool so the hunt was on. autozone only carried a 22 and 23 spline we need a 26. nobody else around here even stocked them. my brother in law the ol gear head had a 26 spline gm sitting in his tool box WOOOT!!!. I didnt shim mine, didnt do the pre adjustment. drove the car last night and felt great. didnt think the pedal was as bad as others seemed to explain and was very tolerable.
Old 09-02-2007, 07:29 PM
noxiouSS's Avatar
cool guys. anything else i might need to know? Little things like knowing to already having an alighnment tool makes the whole install so much smoother!
Quick Reply: Tips for installing LS7 clutch?
