Help - Car wont rev past 1000rpm
Old 09-02-2007, 03:14 PM
drjimmy's Avatar
Default Help - Car wont rev past 1000rpm
I just had a 94 camaro engine rebuilt. The car starts fine but will not rev past 1000rpm with my foot to the floor or part throttle. I dropped my y-pipe to test for plugged cat - didnt help. I plugged all my vacum lines - didnt help.
Computer is not sending any codes. Data from scanner appears to be inline but I am not an expert. Anybody have a clue? Could a bad coil do this?
Old 09-02-2007, 03:19 PM
Slowmaro95Z28's Avatar
Is it holding steady at 1000 or is it breaking up really bad like it has a miss?
Old 09-02-2007, 04:37 PM
drjimmy's Avatar
It actually holds at 1000rpm. Sounds like it is bogging like it cant get enough air. No restrictions in the intake. Took the air box right off.
Old 09-02-2007, 05:44 PM
If the motor was just rebuilt check every connection. Make sure no sensors are left unplugged and take it from there.
Old 09-02-2007, 05:53 PM
C5042081's Avatar
sounds stupid but did the throttle cable break, check if its connected to the TB also look to see if the Tb is opening
Old 09-02-2007, 06:04 PM
That's also a good idea. Try revving the motor by hand from under the hood.
Old 09-02-2007, 08:02 PM
drjimmy's Avatar
The throttle cable is fine. I have reved it from under the hood. Throttle position sensor also indicates 100% when stepping on the gas. An unplugged sensor should give a code. Really strange bug.
Old 09-02-2007, 08:36 PM
dhdenney's Avatar
Like it shows 100% all the time? Or when it's actually WOT? Shows 0% when closed and everything in between?
Old 09-02-2007, 10:31 PM
drjimmy's Avatar
Yes, shows 100% at WOT and 0% when closed.
Old 09-03-2007, 12:58 AM
transam5.7lt1's Avatar
Low fuel pressure? It will not throw a code for a low fuel pressure condition. Check your fuel pressure regulator, if the diaphram inside the regulator is broken, fuel pressure goes back to fuel tank via the return line, if thats the case, not enough fuel pressure is build in the injectors, showing a similar condition as you mentioned.
Old 09-03-2007, 03:45 PM
drjimmy's Avatar
Fuel pressure is 40psi at idle and 45psi under load.
Replaced ignition coil - didnt help.
Old 09-03-2007, 04:37 PM
Even at that fuel pressure, if you have a bad fuel pressure regulator, not enough fuel pressure will build in the injectors.
Old 09-03-2007, 06:30 PM
drjimmy's Avatar
Not really. The fuel pressure is measured at the fuel rail which is at the same pressure as each injector. The regulator bleeds off pressure to the return line. If the regulator was defective, you would see little pressure on the rail.
Old 09-03-2007, 08:34 PM
drjimmy's Avatar
Pulled the valve covers off and reset the valve lash. Still no good. Running out of ideas.
Old 09-03-2007, 08:53 PM
mattdb2377's Avatar
Try checking something as simple as the plugs (gap, boots, etc) My car wouldnt rev past 1k with 3 plug wires disconnected and fuel cut off to another 2 (animal ate a bunch of wires!!!) Maybe the guy who rebuilt it gapped them wrong or messed up the firing order. Throwin out an idea for ya.
Old 09-04-2007, 10:40 AM
Scrapin'4.8's Avatar
maybe cam was installed 180 out???
Old 09-04-2007, 03:15 PM
dhdenney's Avatar
Would it even run with cam 180 out? I don't think it would run.
Old 09-04-2007, 04:54 PM
ThoR294's Avatar
pressure doesn't mean much, you gotta have a flow tester as well to test the flow of the fuel.
Whats the MAF reading and your MAP/BARO readings also when you revv
Old 09-10-2007, 08:15 PM
drjimmy's Avatar
Baro is 29"hg when reving and idle
Maf is 12 at idle and 18 when reving
iac counts is 160 at idle.
Knock retard is 0 deg at idle
spark advance is 15 deg at idle
rpm is 450 and req rpm is 800.
Old 09-10-2007, 08:17 PM
drjimmy's Avatar
How can I test the injector circuit to see if they are actually opening. The injectors themselves were tested prior to installation.
Quick Reply: Help - Car wont rev past 1000rpm
