Clay checking piston to valve
Old 05-29-2003, 12:07 AM
redaddiction's Avatar
Default Clay checking piston to valve
Can anyone give me a little info on this? I want to check my heads/cam combo to make sure it is good to go.
Marc
Old 05-29-2003, 12:10 AM
mighty mex's Avatar
Default Re: Clay checking piston to valve
use a solid roller lifter when doing this
that way you get a more accurate reading
Old 05-29-2003, 07:34 AM
robertbartsch's Avatar
Good question:
I have my heads off and was considering skipping this step since I dont have two solid lifters.
Can I get a general feel for the piston valve clearance if I clay with hydrolic rollers - mine are "R" replacement lifters...
Can you use the old head gaskets?
Please shed some light on this point; thanks..
Old 05-29-2003, 10:20 AM
rsmith's Avatar
I used stock rollers and this procedure to check clearance with clay. You will need some light weight checking springs (as to not compress hyd. lifter)and tighten down rockers to "0" clearance on heel of cam (too tight will hang valve open for false reading) and rotate motor. I use clear Saran Wrap on top of clay so it won't stick to valve. I also used old head gasket for this check.
Old 05-29-2003, 11:44 AM
Do i need to torque the heads all the way down or what? I'm now really worried about this so I'm going to do it just need a little more info.
Old 05-29-2003, 11:59 AM
mobius's Avatar
i would just use the old bolts and gasket for this.
Old 05-29-2003, 12:13 PM
ok thanks alot time to get some play do
Old 05-29-2003, 04:30 PM
Where do they sell play-doe - Home Depo or Martha's place?
ThanX...
