1LE Elbow
1LE Elbow
Any of you guys custom fab your OEM one into an 1LE? Im in the process of doing mine right now (boredom). I was wondering if any of you have done it.
I didn't make one, but I did buy an aluminum from ebay a while back, it was a very nice piece, I no longer have an LT1, but I remeber that it came with silicone couplers, clamps and a good price for the item, it was a company called CRT Performance or something like that.
I did. I cut off the end of a V05 shampoo bottle and crammed it in there, then put a hose clamp around it I'm sure adding some silicone around it would help the MAF guys if it does leak. Running SD I could've cared less. I then found my vortec alu one and that's on now.
Originally Posted by 95 Z28
I was hoping I wasn't the only guy that did that ...worked like a charm.
I was reading about the bottle trick. I had to do a makeshift one.I trimmed 90% of the flange where the tube was off. Then took the tube (resinator?) and cut that into a piece, which filled the whole, and sealed it with some RTV. It hasnt dried yet, but I hope itll work. If not Im going to walmart for some V05!
There was a site explaining a way to do it just like that, but I didn't have the one they listed lol Suave or something *shrug*.
Ah, I knew it was a common brand I was using V05, and it was easy, plus it fit well. I'll snap a pic and upload it here in a min or two.
EDIT: Ah, that's right. It fit so tight I didn't need to use a hose clamp. I just pushed it in as hard as I could and got it flush with the inside of the elbow so it wouldn't cause any air flow restrictions or turbulence.
Originally Posted by ZONES89RS
Which? Paint cap or shampoo bottle? I bet the shampoo bottle has a cleaner feel in throttle response
Well I got my new fuel filter put in (50k miles old ) and put my new/old elbow on. I didnt notice anything except a little bit better throttle response. But if it helped, then it was well worth the 10 minutes I spent on it.
