fueling problem please help
Old 09-03-2007, 02:55 AM
sultan(ZR-1)KSA's Avatar
Default fueling problem please help
hi guys its been a long while since i posted any problems but it seems to have arrived and in Ase's
OK here goes
on idle every thing is fine going up and dawn the RPM on light throttle and all is good
nut once i get on it hard and go above 5000RPM i start to lose pressure
i did some testing to see what is damaged
1-i closed the feed line to the regulator and the fuel pressure went way pass 100PSI , so the fuel pumps are good
2-i burrowed a fuel pressure regulator from a Friend and it showed the exact same symptoms
i guess the only other thing is the fuel filter to change and that is what i will do tomorrow
what do you think guys
Old 09-03-2007, 07:53 AM
theblur98ss's Avatar
I'd start with the filtler no doubt. I wouldn't rule out the pump though. It may be getting weak and not keeping up under load. Make sure there aren't any kinks in the fuel line as well.
Old 09-03-2007, 12:31 PM
thanks
Old 09-04-2007, 08:29 AM
bounce
Old 09-04-2007, 10:46 AM
WHPLASH's Avatar
I have the same problem right now. I posted under the fuel & injection section. I'm going to try the fuel filter first too.
