Where is the Evaporative Vent Solenoid?
Re: Where is the Evaporative Vent Solenoid?
66ImpalaLT1,
Thanks for the fast response and excellent picture, BUT I believe the one you are showing here is the EVAP Purge Solenoid. Apparently, there is also an EVAP vent solenoid somewhere. If I unplug the one you show in your pic, I get a different code: P0443, EVAP Purge Solenoid Control Circuit.
Nope, I just looked there. There's just a hollow cavity were it used to be on the LT1 cars. (I do have a LT1 shop manual for all the good it does.) After following all the hoses, fuel lines, and wires, it appears the solenoid I'm looking for is sandwiched between the fuel tank and the floor pan . . . I hope this isn't true, what a PITA.
On 2001, 2002 F-cars, the Evap. Vent Sol. is on top of the fuel tank (you have to drop the axle to drop the tank to get at the solenoid....);
Well, here's an excuse to get new trailing arms and a new torque arm.... or even a new axle....
Well just as a follow-up, here's what I found: the wire bundle under the left rear seat had a cut in it from when I cut a hole in the carpet to go around the roll bar. Unfortunatly, I didn't find this until I had already dropped the fuel tank and looked for problems there with the EVAP vent solenoid. On the up side, I found that the fuel tank can eaisily be removed without removing the rear axle. You do have to remove the cat-back exhaust, though.
Originally Posted by Cal
... On the up side, I found that the fuel tank can eaisily be removed without removing the rear axle. You do have to remove the cat-back exhaust, though.
Wow I didn't expect to see this old thread come back to life! Yeah, I just let the axle hang with the wheels off the ground, and slid the tank out over the top of it. Went back in the same way, and wasn't nearly as difficult as I expected. No more problems with it since. Thanks to all for the help.
