is it reasonable to expect 390-400hp from this setup?
Old 09-03-2007, 08:35 AM
los bastardos's Avatar
Default is it reasonable to expect 390-400hp from this setup?
the cam is
gross valve lift .567/.571
duration at .050 224/228
lobe separation 112
timing at .050 open 4/50 close 40/2
LS2 heads, comp 7.4 rods and patriot springs
long tube headers
underdrive pulley
on an otherwise 2000 MY engine
has an LS7 clutch to hold the massive power I probably won't be making, lol.
Old 09-03-2007, 09:05 AM
Billy177's Avatar
yea id expect around 425ish to the wheels
Old 09-03-2007, 12:33 PM
allthrotle's Avatar
You should hit those numbers no problem.
Old 09-03-2007, 02:34 PM
silver01z06's Avatar
390 to 400 is possible but i wouldnt expect 425
Old 09-03-2007, 04:13 PM
bursty's Avatar
with the 4.10s and IRS, id say you're more towards 375-390
are the LS2 heads stock?
Old 09-03-2007, 04:29 PM
3.90, car was an auto and still has the auto pumpkin dude.
Old 09-03-2007, 11:32 PM
Billy177's Avatar
didn't realize it was an auto. That will put a dent in your numbers but can help you at the track
Old 09-03-2007, 11:41 PM
01CamaroZ28's Avatar
400 maybe pushing it bc f the fact that its an auto but better track times
Old 09-04-2007, 07:07 AM
slow trap's Avatar
i think it is an m6 but has the 3.90 cogs instead of 4.10 since he said he has an ls7 clutch for all that power he won't be making. anyways i'd say you should be in the area you are hoping for, maybe 385 or so may be closer but you can never tell.
Old 09-04-2007, 11:42 AM
it's not, it's a t56 that's a completely different issue since the motor is going in an rx7 chassis.
