questions....
questions....
I have switched to speed density and it has alittle stumble in it....is this normal for sd or can all of the stumble be tuned out???
I'm going to run 110 octane about how much timing can I run???
thanks in advance....
I have the same problem with mine since going SD and have wondered about this to. My stumble is in the lower rpm just as you tip the throttle in. I didn't expect it to drive this bad with all the threads I read about how good it will be. Its great above 2500 rpm. Mine is different in that its a Procharger.
