Normal for a car to run 10* to 15* hotter when....
Old 05-29-2003, 06:59 AM
StevieZ's Avatar
Default Normal for a car to run 10* to 15* hotter when....
....you're running the AC? My car never used to do that before I put the stroker in. Now there is a marked difference.
Old 05-29-2003, 07:04 AM
Viper's Avatar
Default Re: Normal for a car to run 10* to 15* hotter when....
Well, not qualified to state if this is it, but I'm seeing a trend the last few weeks to go to the SLP radiator for H/C or bigger motors. Food for thought. My temp stays the same with A/C on in my H/C car.
Old 05-29-2003, 08:20 AM
killer01ws6's Avatar
I would say if anything, it should say the same to drop a little, seeing when the ac is on both fans are aways on, not on/off by temp table.
Old 05-29-2003, 09:30 AM
Constrictor 98TA's Avatar
Yes, this is how my car is too. When my A/C is on, both fans kick on, and my temps drop.
Old 05-29-2003, 04:21 PM
StevieZ's Avatar
Well I definitely run warmer with the AC on. Maybe my second fan isn't working. Is there a relay for each fan?
Old 05-29-2003, 04:34 PM
Viper's Avatar
YES! In the front engine fuse box.
