Fueling & Injection - weldon pump hook-up ?
View Full Version : weldon pump hook-up ?
lowbirdws6
09-03-2007, 03:32 PM
ok, this is what i have so far: weldon 600a pump, fast fuel rails w/ instl. kit, a weldon regulator and filter, and a racetronics wiring kit. my thought is to buy a nasty's sumped tank and just run teflon braided lines on pressure and return lines from tank to regulator to fuel rails. any thoughts or recommendations would be greatly appreiciated. thanks :usa:
Nasty N8
09-04-2007, 10:43 AM
Sounds good but you want to run feed from tank to rails to reg. and return back to tank. Oh and you need a pre and post filter for that pump.
Nate
lowbirdws6
09-04-2007, 10:56 PM
thanks Nate, i'll be calling soon for my sumped tank. thanks again.
Jim Craig
09-05-2007, 01:01 PM
At a minimum use a 100 micron filter on the inlet and to protect you injectors from any contamination in the fuel use a 10 micron filter after the pump. Do not (under any circumstance) use a "disc-type" filter with our pumps (no matter what the flow claims are or how "cute" they look).
The 600-A will not make contamination, however it will move it -- we do not use any plastic or phenolics in the construction of this or any or our electric fuel pumps.
