After market Auto shifters
Old 09-03-2007, 06:01 PM
nojdrof's Avatar
Default After market Auto shifters
What model shifter are you using with your 4 speed auto and why do you like it?
Thanks to all!
Old 09-03-2007, 06:18 PM
JustAnother95's Avatar
I've been looking for a good replacement, but I have yet to find a good one, I'm thinking about getting a camaro **** since it looks better than the t-handle IMO
Old 09-03-2007, 07:39 PM
lethal93ta's Avatar
if your running a stock transmission theres no reason to. theres nothing wrong with the stock one.
Old 09-06-2007, 10:27 AM
nojdrof's Avatar
I'm glad you like the stock shifter and I hope you keep it.
Now has anybody found an after market 4 speed auto shifter that works well?
Thanks again
Old 09-06-2007, 10:33 AM
nojdrof's Avatar
I currently have a B&M Megashifters and hate it. You have to pull on it very hard to get it out of park and it doesn't have a good feel. I've spent way too much time adjusting it and it doesn't make much difference.
I would not recomend the B&M Megashifters.
Thanks
Old 09-06-2007, 12:21 PM
InsaneAuto86's Avatar
I have this one and it is SWEET!
http://cgi.ebay.com/ebaymotors/82-02...spagenameZWDVW
Old 09-06-2007, 04:49 PM
lethal93ta's Avatar
Thanks again
I dont have a stock shifter but I also have a th400 transmission, theres no reason to get an aftermarket shifter, a 4l60E should not be shifted manually, put it in D and go, its computer controled, if your shifting it yourself the line pressures are off while your shifting and you burn the clutches up in there.
Old 09-06-2007, 07:31 PM
I agree and I do NOT shift it manually. For me, the different shift **** is for appearance purposes only.
