LS1 Oil Leak
LS1 Oil Leak
I have a small oil leak coming from my LS1, it seems to be by the rear of the motor on the passenger side. It seems the oil is gathering where the trans meets the motor right at the bottom. I can also see some oil on one of the starter bolts, the one that is higher up in the engine. I will try and get some pictures later but it only leaks a drip or 2 a day. I just had a new stall put in so the transmission came out during that. Do you think something could have went wrong when it was put back in? If it was the rear seal, would I see anything when I pop the inspection cover on the trans, like oil or something all over everything? cause It seems clean in there
