My Car Bogs At Takeoff
Old 09-04-2007, 12:12 PM
camarolt195's Avatar
Default My Car Bogs At Takeoff got any idea????????
Hey I Have A 95 Z28 Hotcam Stall And Recently Its Bogging Out When I Take Off It Does It Sometimes Not All The Times
I Changed The Spark Plugs,wires ,optispark, Coil Got An Idea Let Me Know
Old 09-04-2007, 12:16 PM
Billy177's Avatar
do you have a tune with it? Also make sure you have got some gas in the tank, when its real low and you launch you will loose pressure and the engine will bog.
Old 09-05-2007, 09:39 AM
it has a full tank and it still does it oh and no its not tuned
Old 09-05-2007, 11:51 PM
Slowmaro95Z28's Avatar
Do you have the LT4 knock module yet?
Old 09-05-2007, 11:58 PM
Sharpe's Avatar
Exhaust leak?
Old 09-07-2007, 11:04 AM
the headers leak a little from the y pipe you think thats it
lt4 knock module im not sure will that affect the car at take off
Old 09-07-2007, 11:16 AM
It had a pretty big effect on my car before I installed the lt's. The stock LT1 knock module is extremely sensitive. May not be the problem but I couldn't imagine headers with the stock km.
Old 09-10-2007, 12:08 AM
86formula's Avatar
im sure a tune would help some if not get rid of your problem
Old 09-10-2007, 09:02 AM
z_speedfreak's Avatar
that was my problem, the y-pipe cracked at the seem
Old 09-10-2007, 10:45 AM
SpeedDensityZ's Avatar
The car ins't tuned. I strongly advise you to get that done immediatley. The car is probably lean. That will cause a bog as well.
Quick Reply: My Car Bogs At Takeoff
