T56 slipping
T56 slipping
will a t56 slip like and auto if the fluid is low. my car has started slipping a little when im in higher gears (5&6). usually if i try to give it a little gas it will slip for a second and then catch and go. so far only in upper gears. down low it goes good without slipping. I havnt checked the fluid yet but im going to go ahead and change it. its been awhile. any ideas on this. its a stock tranny with a spec stage 4 clutch.
