6800rpm on stock bottom end?
Old 09-04-2007, 06:39 PM
jt76's Avatar
Default 6800rpm on stock bottom end?
Is it risky if the guy im looking to buy the car from has been spinning his bottom end to 6800 rpm. the car has upgraded springs and titanium retainers and chromoly pushrods which is all good im just worries about the bottom end. this is the list of modifications: pacesetter lt headers Y pipe catback Torquer V2 cam on a 112lsa, comp prc double spring kit, chromoly hardened pushrods, ported ls6 oil pump, rollmaster double roller timing chain, yank ss4000 stall, b&m tranny cooler. The car is a 1998 Formula with 91k miles
Old 09-04-2007, 06:48 PM
93redBIRDman's Avatar
what do you honestly think...
Old 09-04-2007, 06:49 PM
98's are one of the years with the "weaker" rod bolts. You should spin it past 6200 very often if you want to be safe. So YES, it is bad that the guy is reving up to 6800, very bad...
Old 09-04-2007, 07:34 PM
JimMueller's Avatar
It could be fine for awhile depending on how much time he's spent above 6200RPM. Hard to say without tearing it down, but I'd be leary of the motor. Not sure what a 'comp prc double spring kit' would be... Associated Spring makes PRC's dual springs, not Comp Cams.
Old 09-04-2007, 07:50 PM
ls2 bait's Avatar
i spin my 99 to 6800 daily with the tv2 but i put in arp rod bolts.
Old 09-05-2007, 01:06 AM
jt76's Avatar
well, looks like im staying away from this car....thanks for the help guys
Old 09-05-2007, 09:16 AM
markp03's Avatar
Or you could lift the motor drop the pan and put in arp rod bolts. There is a write up some where on how to do it.
*edit* I think they drop the kmember out of the way so you can get the pan out...not lift the motor.
Old 09-05-2007, 09:19 AM
Stang's Bane's Avatar
My friend just lunched his motor after spinnning it up that high for 4 months......99 model.
You decide..
Old 09-05-2007, 09:53 AM
Ping King's Avatar
i did rod bolts at the same time i did my cam...i wouldnt play games.
Old 09-05-2007, 11:46 AM
CARTEK Racing
WS6TransAm01's Avatar
I shift at 7000 and hit my 7200 rpm rev limiter at the top of 4th gear every time.
Have 65K miles on my 2001 stock bottom end, I did however upgrade to ARP-RodBolts
Old 09-05-2007, 11:51 AM
Bad Blu Formula's Avatar
So upgrading to rod bolts is the fix. Bam, done.
Old 09-05-2007, 01:39 PM
dug
dug's Avatar
I think the majority of spun bearings is due to oil starvation. A lot of people have complained about dropping oil pressure at high rpms. I read an SAE paper about ls1's and it said oil tends to accumulate in the top end of the motor leaving the oil pan sucked dry. My car would do it when the oil got older and dirtier. After an oil change it was fine.
If the engine sounds good its probably ok. I wouldnt pay a lot for the car though.
Old 09-05-2007, 02:00 PM
allngn_c5's Avatar
I have a 2000 (see sig) and LG advised me that 6800 rpms was about the extent I wanted to push my car. 6700 would be wiser, so for sake of not blowing the motor I try to stay off the rev limiter and shift at 6650-6700 only when racing obviously. I granny shift when not racing. LOL
Old 09-05-2007, 02:03 PM
MrDude_1's Avatar
ive been spinning to 6800 for the last two years.. several times a day most days.
if the motor isnt knocking or broken now.. then its fine. if 6800 worries you, lower the limiter when you get it.
Old 09-05-2007, 02:13 PM
98LS1Formula's Avatar
actually the limiter is set at 6700, my bad I said 6800
its my car and I asked around and did alot of research, nothing is half assed on the car, believe me I am well aware of the limits of the rod bolts
Old 09-05-2007, 02:15 PM
djsanchez2's Avatar
Isn't one of the alleviations to this, drilling 1/2 inch holes in the lifter cups?
I'd be a lil leery about buying someone elses beat on anything. But it's your call.
Old 09-05-2007, 02:24 PM
MrDude_1's Avatar
thats lower then mine... lol.
Old 09-05-2007, 02:26 PM
dug
dug's Avatar
Im not sure what the cure is. I think read something about oil restriciting pushrods. My point is, dont matter what rod bolts are there. no oil pressure
Old 09-05-2007, 03:28 PM
styoung's Avatar
i dd mine that has been spun to 6800rpm by the prevous owner, i put a lot of miles on it too, its a 99. i think its the luck of the draw, some have problems and some dont. i really wouldnt worry about it, but thats just me.
Old 09-05-2007, 03:30 PM
SOM98TA's Avatar
if your getting a good enough deal on the car just install the rod bolts ?
he did the LS6 oil pump and full valve train it sounds like just take it the other step and you should be okay.
