Got before and after dyno graphs of your cam?
Hey all, I'm wanting to build a library of dynos showing before/after of cam installs. If you've tested your car before and after, and have the dyno graphs, email them to me or post them on here. The only difference between the two graphs should be the CAM ONLY.
You can email them to jmx@austin.rr.com.
I also need to know if you have headers, asp pulley, 2001 intake manifold, heads, cats, tuning, and exhaust mods or not.
Thanks!
Thanks!
Re: Got before and after dyno graphs of your cam?
http://web.ics.purdue.edu/~lgigliot/...n/g5x2dyno.jpg
This is RAGEmans before and after, no other changes, cept cam, springs and tuning. AF was 15:1 on the untuned pull, so no "exact" cam only graph could be produced
Louis
Louis
Link for my car just adding an MTI T1 cam & 918 springs
Later I added FLP headers, U/D pulley, & ported throttle body. I have that graph too.
That would be here
With the cam I also got LS1 edit tuning. Other mods I had to start with were a lid and Corsa exhaust. Pulls with headers were through the cats. Car is an A4.
Les
That would be here
Les
