How much RWHP will a 2 bolt main LT1 handle
Mods are in sig, But I have a 93 z28 with a rebuit lt1 (355). I have SRP forged dished slugs making 9:1 compression, forged Eagle H-Beams, STOCK lt1 crank with ARP bolts on the main caps as well as in the heads. Its a supercharged application, and on 11 psi I made 450 rwhp at 6000 ft (596 rwhp corrected)
How much power will my bottom end handle? Corrected #'s aren't as important to me, but in general, how much power is a 2 bolt lt1 capable of holding?
turbo355 over on turbomustangs.com has made over 700 rwhp and run 9's at 140+ mph with a stock 2-bolt bottom-end SBC and Badger pistons. Probably the exception not the rule though. . .
its all about the amount of boost, the tune, and how hard you drive the thing. if you take it out and beat on it everyday of course the thing probably isnt going to hold up long, but if youre talking about it being a weekend warrior i wouldnt worry about it. like engineermike said 700 has been done and i wouldnt be worried to run 500-550 on a consistent basis.
Originally Posted by 97ssmokem
I had 605 RWHP on a 2 bolt and had no problems.
You could probably make 800 horse on 2 bolt mains if you could do it in the lower RPM ranges. I'd say it's RPM that walks the caps, not the power. Any engineers or builders confirm? Also "shock" like sudden nitrous hits too. Just my opinion.
Originally Posted by engineermike
I imagine that the massive cylinder pressures required to make 800 rwhp at, say, 5000 rpm (1100+ ft-lb at peak torque) would cause some cap walk.
So if I splay the block for the 4 bolt mains, how much more rwhp will that support with ARP bolts, and stock lt1 crankshaft? What would it cost me to splay the block?
I wouldnt expect a stock 2 bolt LT1 with any amount of miles on it to stay reliable much past 500. Its all about how it goes about making that much power though. If you rev the **** out of it, it will break sooner than if you were to boost it with a proper FI setup.
Originally Posted by ZONES89RS
Ok, there is a guy in car craft this month and has a 89 GTA with a old *** bone stock 76 350 with twins pushing over 700 RWHP, so that should say somthing.
