So, just did the Home Depot "Husky Red" catch can mod, along with a new pcv valve
Old 09-05-2007, 05:49 PM
Demon Of Dreams's Avatar
Default Home Depot "Husky Red" catch can mod (Now with Pics)
figured since I was going to be doing the PCV valve to begin with (it was long over due I suppose), I may as well spend the $25 and get it done...
lucky enough for me, the Home Depot I went to had two versions, the older one (thinner tube, not much packing inside) and the newer one.... they had different elements but I guess the newer one flows better than the older. I spent $25 total, including a 3 ft length of 3/8" hose, 2 3/8" hose adapters, and a pair of 3/8" to 1/4" NPT reducers since I couldn't find the damned 3/8" NPT to 3/8" Hose (not sure it's even made though) ... Apparently home depot had different product #'s though the SKU's were the same, so the newer one ended up costing $15 vs. the old one at $22.95 ... not a bad deal for me. The only differences in the product itself aside from the filter elements, were the way the tops fitted to the bottoms. The old one was a squeeze and turn sort of deal, the new one is a separate screw ring that mates to the top.
I had to zip tie the canister, I haven't a clue how some people mounted the actual thing, and after a bit of reading here, figured for a temporary fix, a pair of high strength extra long zip ties would be just the thing.
I probably did a bit of extra hose in my install but I don't think that matters a whole lot in the end, it's mounted to the AC canister for the time being.
Install took maybe 10 minutes, longest part to do for me was trying to find a decent enough position for it and which way to point everything without getting kinks and allowing for no rubbing...
prior to this install, I was experiencing my RPM's dropping quite a bit both with the AC on and without, it's not a charging problem, and both my alternator and battery tested well ... so it's either this, or an IAC valve and I don't fancy spending $130 on one of those yet, so I'm going to see if maybe I just had a slight vacuum leak causing a problem or not. will find out when I go out for dinner in a bit I suppose.
not a hard thing to do at all, for very little invested, sure it's not one of those nifty $100 pieces, but it'll do in a pinch
Not the cleanest of installs, nor is it the cleanest of engine bays, as it's a daily driver, and living in Houston with construction everywhere you go, it's hard to keep it clean
But it was a quick, zero hassle install.
Old 09-05-2007, 07:12 PM
ND4SPD _SS's Avatar
Old 09-05-2007, 07:16 PM
nexvctm2001ss's Avatar
LOL
Old 09-05-2007, 07:17 PM
ND4SPD _SS's Avatar
thanks ********.lol
Old 09-05-2007, 07:24 PM
Originally Posted by ND4SPD _SS
thanks ********.lol
LOL
Old 09-05-2007, 08:06 PM
98SS1LWEE's Avatar
yeah, would love to see some pics, i'm having some major blow-by issues and probably could use a catch can pretty bad
Old 09-05-2007, 10:15 PM
will get them in the AM, promise.
it seems to have cured my idle dipping problem for the time being as well (new PCV valve was 3 bucks), haven't caught any oil just yet but I don't intend on checking it every day.
I'll be doing my tranny and torque arm mount as well tomorrow
and my fuel filter, figured i may as well get it out of the way since i'll be under the car
Old 09-05-2007, 11:33 PM
Eddie 70's Avatar
Looking forward to seeing the pics.
Old 09-06-2007, 12:55 PM
bump with pics
Old 09-06-2007, 12:56 PM
I also have to add, until I can do a bracket for it, I realize it is a lot of extra hose ... I saved the stock elbow that comes off of the PCV valve for when I can do it correctly, and everything else more or less remained in it's stock location (I believe some tend to modify the routing of the pcv itself, I chose not to)
Old 09-06-2007, 01:20 PM
14 Second Truck Club
mzoomora's Avatar
Is that an in-line air dryer?
Old 09-06-2007, 01:27 PM
without the filtering element and other pieces
sure beats paying an additional $75-100 for one at the moment
Old 09-06-2007, 01:36 PM
99_Z_155's Avatar
Pardon My Ignorance, But Why Would One Need This Setup? Are You Experiencing Like Some Oil Blow By Where You Have Leaks? I Guess I Dont Understand Why Guys Are Doing These Catch Cans. Can Someone Please Help Me Out?
Old 09-06-2007, 01:42 PM
99blancoSS's Avatar
good job, your right that engine bay is ugly
Old 09-06-2007, 01:55 PM
it hasn't been cleaned since I bought it over a year ago (the engine bay itself) ... just don't have the time, and it'd be filthy in a week again anyway... everywhere I drive there tends to be construction, so between the massive amounts of humidity and dust, and it being a daily, it's hard to keep it clean
Old 09-06-2007, 01:56 PM
don't really have leaks, it's more preventive maintenance at this point... but I figured I'd get it out of the way since I was doing some small fixes under there anyway
Old 09-06-2007, 03:56 PM
mzoomora's Avatar
Take off a LS1 intake that has 40k miles on it and look on the inside, you will see why people do this.
Old 09-06-2007, 08:19 PM
Mike94ZLT1's Avatar
Holy **** you win the dirty LS1 award of the year!
Old 09-06-2007, 08:52 PM
98SS1LWEE's Avatar
Old 09-06-2007, 09:36 PM
2000Hawk's Avatar
Im going to pick one of these up, thats a good set-up you got there. I'll probably keep it for a while 'till i got the money for a catch can.
-Joel
Quick Reply: So, just did the Home Depot "Husky Red" catch can mod, along with a new pcv valve
