Why is Tuning a Torquer 2 so difficult or unfriendly?
So here's my question. I used to have a torquer 2 on a 113lsa and Went to get it tued, and was ragged over it with tuner saying he hates tuning this cam. Then again, i had a buddy get the same cam on a 112 and two more tuners were like....oh no, blah, anything but the torquer. Please oh plese you knowledgeable tuners, please tell me why it's so difficult or unfriendly?
Thanks for your Opinions guys
I dont know considering my cam is similiar to to it, I didnt have issues really and i tune myself. A tuner that cant tune a tourquer isnt the greatest tuner. But then again good tuners are damn near impossible to come by IMO.
There really is no reason to not like tuning that cam, its not a huge cam and depending on the lsa its cut it wont have too much valve overlap to deal with.
What cam are you running now?
well its my cam he is writing about and i have an 02 six speed just bought the torquer 2 and am concern because when my friend went to get his tuned everyone kinda got a little upset cause they said that this particular cam is harder then the others to tune. and i understand that its not a huge cam and all that other good stuff, this is why i am asking if any one could explain why this is and if anyone with the exact cam has ever had a bad tune or trouble. im just trying to prevent trouble if there was any. i know alot of people have good things to say about this cam and believe me im excited and still am putting this cam in. Just want to no what to expect. thanks
Well the difficult to tune statement doesnt make sense and any tuner that says it is a difficult cam to tune would not be tuning my ride. The TQ 2 is 232/234 113 LSA and I have a 232/236 112LSA in my car and my car is not difficult to tune, although i have a good set of heads and high compression, but still the cam behavior is still similar. These are not big cams at all and tuning is not very hard to do. If they thing a TQ is hard, good luck with the Trex.
what's your lift? Is it similar too? also, the LS6 heads help the trex, and gosh i know it won't be easy to tune in any case. I just was curious as to why they griped about the torquer. They actually would prefer to tune a very large cam only compared to this particular cam. That's why i didn't understand. It woul dbe different if i only heard it from one tuner. Also,jsut a little curiosity. Untuned i know of two different torquer 2 cars that idled on thier own and drove decent untuned, but after tune, surged more and had dfficulty idling. Very interesting to me
Mines like .585 on lift. I tend to think the difficulty comes from the fact that you know that you have a somewhat small cam so you expect it to be driveable whereas with the large cams like the Trex you expect it to not be so driveable, so the tuner doesnt have to worry much about drivability with the large cams. Thats my take on it.
Mine ran Ok untuned, I just turned the setscrew on the TB a little to help it idle better before I tuned it.
Alot of tuners, even "pro" tuners patch alot of **** to try and make a big cam run right. I retune about a car a week from a shop near me. Guys got a great rep, but churns out **** constantly.
If they are setup properly, everything seems to fall into place. You end up needing alot less throttle cracker, follower, and some of the other "tweaks" that some guys use to make em run right.
Anybody can make em put up numbers. Its the driveability that makes or breaks a tuner.
Originally Posted by edcmat-l1
That cams no big deal at all. Find another tuner.
I think you might be missing the point. They didn't tell me it's hard to tune, like in they can't get it good or right, they don't like to tune it, like it takes a bunchof changes or soemthing. is this possible? Like i know a bunch of big tuners ahve saved tunes, and maybe there saved tune for this cam varies alot between cars. Is this possible?
yea with the torquer i would like to crack 400rwp but in truthfully, i would so much give that power up as long as i cant still drive it everday. i can deal with a little surging, but the way they were making it sounds im doing the worst thing to a car one person could do.
Those cams are no harder to tune, or make run right, or get the low end driveability good, or near perfect, or however you want to word it, than any other cam with the same overlap, and therefore the same manifold vacuum and reversion characteristics.
I've tuned two of them now. They're not difficult to get drive-ability or AFR right. Knowing how to get rid of the bucking is where the problem lies for many tuners. Most tuners throw a lot of timing at a big cam like that (like the guy that tuned my car - running 232/238). In reality, the idle and low RPM fueling requirements are a lot less than stock. Such a small amount of fuel doesn't need nearly as much spark advance. FYI, I pulled nearly 12* of timing out of my spark map for low RPM/low airflow scenarios. Hardly bucks at all now.
well, to be honest, i wish one specific tuner hadn't told me this, cause now after two cars to them and negative results after tune, i am very disappointed. I will keep them anonymous cause all i can say other than this is amjor good stuff, but this is just a small let down
