Rocker arm contact patch with ETP 240 heads
Old 09-05-2007, 06:12 PM
Jimmy P's Avatar
Default Rocker arm contact patch with ETP 240 heads
Has anyone had any issues with ETP 240 heads and the rocker arm contact patch using stock rockers and the ETP pedestals? Me and one of my buddys ordered two sets of ETP 240 heads, and both of us are having the same issue. It seems the rocker arm only touches about 1/3 of the valve. It seems that if the pedestal was a little bit thicker, it would be ok. The other option would be to buy some adjustable rocker arms. What do you guys think?
Old 09-06-2007, 01:22 PM
ATVracr's Avatar
You might have to shim the stand up.
I think we have 30 thou. under mine. Try some different sizes to see what works best for your set up.
Mine is not 100% perfect but VERY close and I've been running my stock rockers for well over a year now with no issues.
Old 09-06-2007, 04:17 PM
Jimmy P's Avatar
Yea..I figured I may have to shim it up. The problem with that, is that I need to have a machine shop fabricate that type of piece for me. I can't just place a couple of shims under the pedestal, because it is a long piece and needs to sit flat.
Old 09-06-2007, 09:45 PM
ATVracr's Avatar
I have 30 thou. washers under the pedestal, one for each rocker arm bolt.
Works great.
Old 09-07-2007, 11:32 AM
427's Avatar
The square shims for a sb Ford work well also, just shim every bolt the same.
Kurt
Old 09-07-2007, 12:46 PM
ATVracr's Avatar
Kurt
Kurt,
I use the round BBC shims, they make more HP then the ford ones.
Old 09-07-2007, 02:12 PM
427's Avatar
LMAO.
Kurt
Originally Posted by ATVracr
Kurt,
