Now i think my bottom end is blown. Bad knock/Scretching
Original Link
my cam dowel came off the cam sproket while i was racing. and the motor shut off i pulled the heads and replaced them with some 241's and put my good springs on there. re tightened my 3 bolts going on my cam gear sproket. When i pulled my drain plug there was metal shavings along with the cam dowel. So i went ahead and did all that.
Once everything was together i started it and got this loud scretching/knock/taping noise. im assumin i spun a bearing or something along the line with the bottom end.
im so frustrated beyond beleif ive been working on my car for the last 3 days to come to the end of this...
tomorrow morning my car will be towed to a shop to have a new motor built.
Originally Posted by theblur98ss
I had a motor do that and it was spun rod bearings.
Yeah the bottom end is toast, pull it out and take that block to the machine shop and have then bore the cylinders for 347CI and get a line hone. Then put that bitch back together with new forged pistons and rods ect...
If you got 241's I say trash the block and go lsx. Now's the time to go big cubes if you're ever planning on doing it in the future! Once you got a freash 347 with 0 miles, you'll never wanna do it!
big cubes or go home!
can decided on what bottom end i want. 347 383 408 help? im on a tight budget but i want a BADASS bottom end i dont wanna have to worry about and i can spray the **** out of and rev the **** out of and beat the **** out of.
hah
hah
hah
hah
If you want a bad *** bottom end...do you want a forged crank or retain stock crank to save some cash?
the bigger the stroke the more stress you put on the crank by "revving the ****" out of it lol.
If you remember TINKRD's old set up, stock crank, forged rods and pistons etc...was spraying 300 on top of it...that enough spray?
If I were you I'd either rebuild it to stock or just put rods and pistons in it and worry about spraying and your fuel system later when you have the cash to do it right the first time.
I love my iron 408. Its iron so its heavier, but I don't have to worry about it because it's strong as hell. It's setup for spray too, so its good to have as much strength down there as you can get. Its like wearing a cup in baseball. You could probably play a whole season of games without one, but if you get hit in the sack, you'll be cursing yourself for not wearing one as you roll around amongst the grass and dirt holding your crotch. I say build it strong, and then forget about it stock cubes or not. Then you can **** on it as much as you'd like.
If you want a cheaper route either get a forged 347 from a vendor on here or have your motor rebuilt with forged pistons & some Callies rods w/ARP bolts. Thats the cheapest route you could possibly take.
I wouldn't waste money on a forged crank since the stocker is good up to like 800hp.
If the car isn't your main transportation just call it a year and save, save, save over the winter and build what you want. I'd say a 408 would fit nicely. Order it around Feb and have it for spring.
