Compression question?
I was about to buy an STS kit when I came across a short block that I couldnt pass up. I would be an idiot if I did. The guy got into trouble with money and was practically giving it away. It's a 396 with 4 bolt mains, and forged internals. It was built with the intent of using LE3 heads to acheive a near 10:5 to 1 compression. Now Im not any good with math so hears my question: If i were to bolt up a set of ported trick flows (have laying around) on this motor, I would have around a 9:8 to 1 compression? With the motor being forged Im still going to buy the STS kit and push around 9lbs (street) 12-15lbs (track). Is that compression low enough for that much boost? Thanks for the help
