candlelit
09-06-2007, 06:36 PM
I'm really leaning toward FI now. Here's my setup:
M6 car with Textralia OZ-700, rebuilt trans
stock 346 LS1
CNC Ported 241 heads
Comp Cams 224/228 .581
LS6 Intake
Stock 10 bolt
Hooker long tube headers
How much would you think the compression rate is? Would it do good to throw a supercharger or turbo on it, or should I figure out a way to lower compression first?
I was thinking about a big nasty NA setup. But my car is driven everyday to work and lunch and home, about 10 miles a day.
I've been seeing some BIG numbers with heads, cam, forced induction. I want to be able to run about 12 PSI. Therefore, I think I want to upgrade my shortblock... pistons and rods. Does it matter which pistons I should get? A polished or forged crank won't help, will it? And what would you recommend for a FI system (one of the cheaper setups). I'll probably buy used on this board.
Thanks to all that will reply!
stock 346 LS1
LS6 Intake
Stock 10 bolt
