Whats wrong with my car?!?!
Well any time I get on it and take the RPMs up it feels like I am letting off the throttle and stomping back on it over and over again. It used to only happen in 1st but now most of the time it won't happen until I shift into 2nd. Alot of the time it pulls the SES light and it shows 2 MAF codes. I used a whole can of CRC Mass Air cleaner on it hoping that would help, but it didn't. I know its likely that my MAF is going out and needs replaced, but the SES light goes away after turning the car off and back on. Wouldn't the light stay on all the time?
Again, imagine getting the RPMs up over 4k and taking your foot off the gas and quickly stomping back on it again and again (obviously by then I have let off to avoid looking like an idiot to surrounding drivers)
What do I do to check the voltage on the MAF, snap the throttle to WOT, sweep it slowly, or what?
Had the same issue with my 99 Z, turns out it was a bad spark plug wire (Headers burned it) and when I really got on it it would stumble (or rev up and down). The wire would cause the computer to adjust the engine and make the motor go crazy, however it would only happen above 3,000 rpm.
