Gears & Axles - moser 12 bolt vs. moser 9"
View Full Version : moser 12 bolt vs. moser 9"
josh2002-ws6
09-07-2007, 10:44 AM
For my application what would everyone recommend? I have everything in my sig plus will have my LT's on in the next couple of days. I will be going down the road of heads, cam, and nitous over the winter. My goal is to get this car into the 10 seconds range.
Stang's Bane
09-07-2007, 10:56 AM
9" ???
ICRAZY6
09-07-2007, 12:27 PM
9" all the way for 6 speeds. I've got an auto but still planning on purchasing a 9". Some of the sponsers on here have real good deals too. Check them out=======>
JScamaro
09-07-2007, 01:36 PM
I would definitely go with a 9" and not have to worry about it still breaking.
EPP has a nice site that will answer a lot of questions and give good info. Check them out.
02 Silver SS
09-07-2007, 01:41 PM
9" = can handle 900+hp and is 100 lbs or so more than 12 bolt which can only handle around 600-800hp
Ericbigmac83
09-07-2007, 02:00 PM
Since when is a 9" 100lbs more than a 12 bolt? it cant be any more than 15-20 lbs heavier, anyone have numbers?
koolaid_kid
09-07-2007, 02:42 PM
I suspect the weight estimate is a bit overstated.
Also, it is not the horsepower ratings that kills the 12 bolt with the M6, it is the sudden shock of a 4k dump and the stickiness of the rear tires that can kill the 12 bolt. An auto does not have this sudden shock so the 12 bolt is usually fine.
EPP
09-08-2007, 04:47 AM
I'd go nine inch, the 12 bolt is actually more optioned out. Bob
http://www.exoticperformanceplus.com/performance_parts/index.html?item=145
