New Gm Cams
New Gm Cams
I got a release that GM has 2 new cams out specs are as follows:stage 2
227/239 duration @ .050 lsa 108 .324/.324 lift at the cam, stage 3 233/276
duration 107 lsa .350/.350 lift at cam. Any thoughts on what kind of power
one of these cams should make or what kind of manners they would have.
LS1TECH & Trucks Sponsor
It's true, those are the real specs!! We generally keep them in stock too!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Wonder what the intended uses are. Anyone know the final lift numbers?
I wouldn't mind trying out that stage 2 cam.
Found em.
Stage 2: 227/239 .551/.551 LSA 108
Stage 3: 233/276 .595/.595 LSA 107
w/ 1.8 rockers lift goes to
S2: .556/.556
S3: .630/.630
Found em.
S2: .556/.556
S3: .630/.630
Originally Posted by NemeSS
sounds like they are designed with l92/ls3 heads in mind.
not sure about the 276*duration on exhaust on the second cam,
links?
links?
S2: .556/.556
S3: .630/.630
S2: .556/.556
S3: .630/.630
ASA cam: 226/236 .525/.525 LSA 110
