Mistakenly used antiseize instead of threadlocker
Old 09-07-2007, 02:24 PM
niqdiezel's Avatar
Default Mistakenly used antiseize instead of threadlocker
When I reinstalled my new clutch and flywheel, I mistakenly coated the bolts with antiseize instead of threadlocker. I didn't realize what I've done until after I put the transmission back in the car. I really don't want to take the transmission back out, but do I have to? Thanks in advance.
Old 09-07-2007, 02:27 PM
niqdiezel's Avatar
By the way, it's a 99 trans am with a ram clutch, a fidanza aluminum flywheel and ARP bolts
Old 09-07-2007, 03:26 PM
TheLS1Kid's Avatar
I would take it back out just to be safe.
You dont want that **** coming loose at 6500 rpms.
Old 09-07-2007, 04:49 PM
Mike454SS's Avatar
I'd tear it apart, clean the holes out a LOT to get the antiseize out (use brake cleaner or something equally good) and clean the bolts as well, then apply lock tite and put it back together.
The good news is, none of those bolts will be seized
Old 09-07-2007, 05:41 PM
niqdiezel's Avatar
Thanks guys.
Old 09-07-2007, 08:23 PM
brad8266's Avatar
yeah id pull it again, you do not want the flywheel bolts or PP bolts coming loose.
Quick Reply: Mistakenly used antiseize instead of threadlocker
