Adding ground clearance with QA1s??
My car is just too low in front and I need to bring it up apox 3/4" or so. The springs are oed315-s How much do you think the spring seat needs moved up for that much change in ride height?
Also is it normal for the spring seat nut and the jam nut to be hand tight once spring tension is removed?
Originally Posted by foggedz
I think that basicly the amount you move the spring seat up is the amount the car will raise. If you want it to be 3/4in higher raise teh spring seat of 3/4in.
