what HP to replace LS6 clutch?
Old 09-07-2007, 04:14 PM
danf1000's Avatar
Default what HP to replace LS6 clutch?
Planning some additional mods this winter. This will put me in the area of 460 to 480 HP Rear wheel and around 30 less of torque.
What is the best that the LS6 clutch can take. Occasional drag racing here but not so much dumping from a standstill (10 bolt).
If it is time to replace, what is a good substitute? I would be looking for stock reliability and decent feel. Not concerned about weight, there is something about the feel of a large rotational inertia setup having it's way with a car (C6 Z06??).
Old 09-07-2007, 05:06 PM
ConElite's Avatar
Your better off getting the LS7 Clutch/LS2 FW. I just installed that after going through the stocker and 2 pos SPEC S1 clutches. Its about 17 lbs heavier than the stock clutch but It holded like a SOB. And for the Price you cant beat it. I also invested in a Remote Bleeder to make it easier to bleed. My 00 T/A is a DD and I just say, Its absolutly smooth and very light. Feels better than stock.
Old 09-07-2007, 07:19 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
The LS6 clutch in my TA took a **** after about 100 miles once the H/C were installed. They don't like high HP cars
Old 09-07-2007, 10:25 PM
danf1000's Avatar
so the LS7 clutch then, for stock-like feel. and this will hold my expected level of HP?
Old 09-07-2007, 11:10 PM
Z28/2002's Avatar
My car is making about 440-450 right now and I am very impressed with the LS7 clutch.
Old 09-09-2007, 07:31 AM
danf1000's Avatar
for clarification, that is rear-wheel hp, right??
Old 09-09-2007, 08:49 AM
GG01SS's Avatar
I have been looking for new clutch as well, and since I do not plan on spraying, I will be going with LS7. But I here they will not hold much more than a 100 shot w/ full weight car.
Old 09-09-2007, 11:06 PM
Z28/2002's Avatar
Yes that is RWHP. It should be in the 460-470 range after the UD pulley and FAST 90/90. Then she is getting hit with a 150 shot
Quick Reply: what HP to replace LS6 clutch?
