changing shift points in A4 with Tech II >>???
Hey I work at a Pontiac delearship, and I have access to a Tech II. Is it possible to change the rev limiter and shift points on an 01' WS6, with the Tech II?
TIA.
TIA.
Re: changing shift points in A4 with Tech II >>???
it is baiscly a scan tool like ATAP, it may be possible but you would have to get a special program from GM that I doubt you can get your hands on it.
LS1Tech Co-Founder
Not permanently, just temporarily thru the Tech II.
You can also manipulate the idle (temporarily) and use it to shift the trans.
